Apparently the Van Ordt Pow-R-Stick also uses multiple (4) parallel elements. I believe they’re helical in the Van Ordt antenna. Though, I think this one is off to the history books, also.
Also...though the sample size of shorter antennas is small, the test does tend to show another thing I’ve long noted, below 5’ antenna performance drops sharply.
Jeff, could you give me some dimensions from your Francis, the part in dledinger's post above for Fig 7, showing the base hub ferrule. I'm looking at the mounting ferrule with the fiber glass inside. I'm also curious about the FG tip diameter. I asked my kids to look for mine in the garage, but they could not find my orange or my gray antennas.
I'm redoing my Eznec model similar to the one noted in Fig 8, in the pattern shown on sheet #3, in dledinger's post #24, above.
I would like to know the diameter for the FG at the base right above the mounting ferrule.
I would also like the FG diameter at the tip.
If you can, check and see if you can see any wires showing anywhere on the outside, a few inches below the tip, or at the tip itself. I seem to remember the FG tip being about <>1/8" inch in diameter. I also remember the wire was very small, maybe 1/32" and very hard to cut. Maybe it was made of steel with a very light blue silver color, but my memory is not so good anymore, so I need help.
...that he searched around looking for RF hot-spots, and he would park there and shoot skip....
I do my DXing from public access points on the inter-coastal waterway. Doesn’t much matter for DX under 1000 miles, but it sure helps with the long range stuff. I always try to make a few contacts while crossing the high-rise bridges to the islands, too!!!
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
