FRANKENSTEIN CREATION?
Dmans
Sr. Member
Jan 22, 2017
1,474
1,965
173
Georgia
All,
After seeing kopcicle’s post (see below) in an earlier thread, my twisted mind started wondering.
I have a very clean Regency Range Gain DSB base that was given to me awhile back. It will power on and transmit (with low output-may or may not be on frequency?) it will receive (with low sensitivity) so it really needs to be restored. I believe a conservative estimate would be well over $200.00 to accomplish this. Much more than I would like to spend on this radio. The face is clean, the cabinet is clean and has a cool “retro”look to it.
Now If you ever do find a classic for pennies that has had a botched grip of mods I'm sure you can find a Console V or a DAK X , or a browning that has its guts burned out and needs a heart transplant. Just rip the guts out of the turd and install them in something pretty .
I have recently come across a “Made in the Malaysia” 148GTL for a cheap price (just in my wheelhouse as I am notoriously cheap/thrifty) and am considering merging the 148 into the Range Gain cabinet.
My goal would be to have a fully functional 40(+) channel AM/SSB radio in a classic cabinet retaining as much of the original Regency look from the outside as possible.
Questions I have include:
Is it possible to use some of the receive tuning circuitry of the Regency? (Tube radios are notorious for tighter receive)
Is it possible to use the output and/or modulation sections of the Regency?(for cleaner stronger output as per most tube radios)
Just Sticking the 148 chassis in the Regency seems like a “cheat” to me but combining the best elements of the two radios could be very interesting!
Any thoughts? Flames? Warnings?
73’s
David
More thought brings more questions.
I.e. obtaining a Longer ribbon cable between channel selector/board and channel display/board.
Using Regency receive tuning circuits & output/modulation circuits would require retaining hv transformer, some tubes the expensive 3 section capacitors etc.
Maybe a clean install of the 148 chassis while retaining as much of the stock look is the way to go for the Regency Range Gain CXLVIII??
73’s
David
I like your thinking, David.
I have thought about purchasing a Uniden 980 and trying to find someone to install it in a nice, gutted vintage base station cabinet.
Reactions: Dmans
Riverman71,
I have more mobile radios than I can count and not 1 is installed. I grab them recap them and make small repairs as needed and shelve them.
After kopcicle’s post, I started thinking about and have convinced myself to get started. If it doesn’t work out, I’m really not out much but time.
The Regency is a good looking unit but still only 23 channels. Although it is a double side band, to get it to work correctly (as in restoration $$$) and put it on 27.3850 and up would require more financial investment than I am comfortable with.
I have high hopes but that’s not going to be enough. I will need help from the smart people on this forum.
Stay tuned!!
73’s
David
Reactions: Riverman
I was thinking of installing a new power supply and amp inside my Trinidad III, beautiful case would make a real sleeper
http://nnamd.duckdns.org:8073/
David,
Depending on where in Georgia you might be able to see your signal here.
The ear can deceive. I have several MB8719 boards ranging from the Grant to the 140/142 GTL. The 148 is second gen, not far removed from the BIG crystal.
Schottky diode mod
Hand built crystal filter. Select, sweep, adjust, repeat.
Doubled up 455 filter
Bandpass filter 6db down @ 26.6 and 28mhz
Close attention to receive stage gain.
2SC1306/1307 with active cooling . (old CPU coolers and fans)
Multi turn potentiometers on the driver and final bias.
5 pole Chebyshev filter
AM power adjust only 560 ohms above ground
Limiter intact but a 5k ohm inserted in the sense line.
8 volt supply for AM lifted at the jumper from the MB3756 and B+ from the filter cap applied instead.
Power supply was in a word overkill. 10A draw won't sag.
Driver and final supply chokes rewound for better current carnying capability.
Turner Super Sidekick with a somewhat higher impedance cartridge that is (for my voice) flat from 40-4K
Graphic equalizer between mike and radio. I kill 120Hz and down, 3.2Khz and up.
Receive audio is delivered to either an old Fischer stereo or a somewhat upscale sound card in a workstation.
I really have to stop here and get technical. The computer isn't normal at all . You see there are laptops, desktops, gaming rigs and workstations. Mine is 8 cores@3GHz with 32G of 1.6GHz ram, 4T Raid 6, Nvidia Quadro SLI, 24-bit/192kHz development card. A beast. I have real time audio processing available that most do not. Still no matter what the processing it's still transistor and not tube.
Back to the radio. I had the advantage of some good gear to look at the radio RX and TX. Although it could be turned down to 500MW and swing to the rail it looked ugly. On the other side of things it would go into compression around 7.5W. A bit on it's 1db compression limit, It looked like the audio chip distortion begins to take over around 7W so it really isn't dependent on RF linearity exclusively.
On SSB carrier suppression was excellent for the design and parts used. Sweeping the filter endlessly and careful tweaks help. Wash rinse repeat...
Okay, so that is a heavily modified radio. I have a Grant that is nearly stock save for a tune up and AM power mods.
I also have an unmodified 148 GTL small crystal .
Now back to
It's the closest full, general coverage SDR I could find and this may change by day by day.
These radios are surprising and somewhat predictable on transmit. Even without extensive filter modifications they are "brick wall" on the opposite side (up freq on LSB and down freq on USB) and only slightly less on the near side due to audio frequency peaks . They all predictably suffer from the usual "blowing out the sides" if the mod limiter is removed, if heavy clipping, processing is used, or if there is enough AM output that the distortion limits of the 7222 are exceeded.
On receive there is the inescapable difference between the single and dual conversion radios. The single conversion radios may hear what the dual conversion may miss bu the dual conversion radio will hear through man made and atmospheric noise. Curiously the noise blanker in the single conversion radios works better , to my ear anyway. Only my saturated, over modified, wash rinse repeat filtered, used to be a TR-296 board, Frankenstein radio begins to compare with my , wait for it ...
uPD858 (TRC-458)
Lastly neither the single conversion 8719, the dual conversion 8719, (modified or otherwise) the or uPD858 can be identified or separated from one another or my TS-830S by listening to or looking at the waterfall on a web SDR site.
Back to business. Tube receivers are overrated. Tube audio amplifiers are not . Any of the above receivers will out perform all but my Hammarlund HQ-170 or Hallicrafters SX-42 . I do own one audio DSP "shack in the box" a FT-857D Yaesu that will absolutely wear me out in short order. I have one experiment sitting here that will have to wait for winter. I have a class "A" tube audio amp that I want to graft to low level audio out of any of the above transistor receivers. Look up "tube headphone amp" for reference. I seriously think that not nearly enough attention was paid to the audio output of any sand state CB. Just a look at the white papers for the Ta7222, Ta7205P or the 1156H shows that the designers felt upwards of 10% THD was acceptable at less than 5w output. If anyone (Chris, Andy?) wants to chime in with the differences between voltage amplifier and current amplifier distortion please do . I just know that if I have a choice I'll gladly listen to voltage amp (tube) distortion.
Conclusion
I'll gladly accept advances in transistor receiver design if I can listen to the warm glow of vacuum tubes.
I'll willingly ditch present day audio dsp for a tube audio output. Give me a true IF DSP and all bets are off other than I still crave filaments in my audio chain. My ideal then would be either a dual conversion 8719 or the uPD858 with tube audio output, grid driven (swamped grid input for stability) single 6146 output, direct digital synthesizer tuning with RIT, wash rinse repeat filter (8719) or careful impedance termination (uPD858) in a DAK X case (modern) or Hallicrafters SX-28 case (retro) . No I wouldn't butcher a classic it would be reproduction.
Sorry for the rambling stream of consciousness brain dump (no I'm not) but I wanted to walk the thin line between dry data sheet specs and personal experience. Obviously I've given this some thought but as always life intervenes
The yellow Robyn was great while it lasted. They tended to age fast, ran really hot inside.
It's the only radio I remember that has the 10.24 crystal on a tube-type oscillator, feeding into the PLL chip's reference-frequency input.
Panasonic never wasted anything in their designs.
Reactions: Dmans
It worked well for a simple AM only transceiver - she had noise around her but the radio even at an idle help keep her bedroom warm.
Good memories...SIGH :):(;)(y)(y)
Very straightforward - didn't require much maintenance - just pull and wipe the tubes to keep the dust down and the sockets burnished by pulling and inserting the tubes. Nothing special about it - really didn't want to put a sweep tube in there - it'd kill it - so for "stock" 3.5W ~5W and mediocre modulation - worked well for a home brewed station.
Reactions: Dmans
All,
One of the many radios that I had in my younger years that I wished I had never gotten rid of was a Shakespeare GBS-240. Same Panasonic chassis as the Robyn Yellow Bird but did not leave the filaments powered up when the power switch was off. (It did have a stand-by mode though) Man, what smooth receive audio!!! I’ve been cruising e-bay for years but they never seem to show up. One day one of them will and I will snag it!
Kopcicle,
Thanks for the inspiration of your post that launched this idea to merge the Regency Range Gain and RCI/Cobra 148. I only wish I had the tools and knowledge to merge the finer points of these two units into one.
Nomadradio,
Kopcicle’s inspiration immediately had my mind flash to a former avatar picture of yours of the Eagle MKIII AM transmitter showing a digitally displayed channel “7A” furthering my inspiration as well as a D201 modified with a Cobra 77X (I believe) thread.
Handy Andy,
Thanks for all of your posts! I never fail to realize how much I don’t know!
Possibilities are limitless!!
73’s
David
Kopcicle,
I will check the link when I get home Sunday. Vacationing on the Florida Gulf Coast at the moment! (y)
I am about 15 miles SW of the Atlanta Airport. If the receiver is indeed in Wetumpka, AL there is a chance I could “see” my signal.
Thanks!
73’s
David
I would love to keep the Regency stock meter in this conversion as well as the “S-V-C” meter switch. I will post pictures of the Regency when I get home. Has the retro green color with chrome outer case.
73’s
David
    AKA- UDX122
