FTA-850 probleme
marcelcote
New Member
Dec 17, 2021
2
hi i these not if someone can give me a hand here my vouchers!
Right here ,
I have a Yaesu FTA-850 that I want to connect to my BLUETHOOT Sena SF2 my as by chance my radio does not find the SF2. So i thought i should update my radio
A software version
main: 01.01.00
Date Aug 31, 2021
Sb: 01.01.00
: Aug 31, 2021
As I log into my PC I have this famous error: Timeout !! (FirmVer) and I can't even read what's on the radio
If anyone can give me a hand it would be greatly appreciated
salut je ces pas si quelqu'un peux me donner un coup de main ici mes bon !
‎Ici‎
‎J'ai un Yaesu FTA-850 que je souhaite connecter en bluethoot sur mon Sena SF2 car par hasard ma radio ne trouve pas le SF2. Alors j'ai pensé que je devais mettre à jour ma radio
‎Une version du logiciel‎
Principal : 01.01.00
‎Date 31 août 2021‎
Sb : 01.01.00
‎Date : 31 août 2021‎
‎Alors que je me connecte sur mon PC j'ai cette fameuse erreur : Timeout!! (FirmVer) et je ne peux même pas lire ce qu'il y a à la radio‎
‎Si quelqu'un peut me donner un coup de main ce serait grandement apprécié‎
I have a Yaesu FTA-850 that I want to connect to my BLUETHOOT Sena SF2 but my radio does not find the SF2. So i thought i should update my radio
A software version
main: 01.01.00
Date Aug 31, 2021
Sb: 01.01.00
: Aug 31, 2021
If i connect my radio to my PC I have this famous error: Timeout !! (FirmVer) and I can't even read what's on the radio
A software version
main: 01.01.00
Date Aug 31, 2021
Sb: 01.01.00
: Aug 31, 2021
Hi,
Did you ever find a way to program your FTA-850 via the software (YCE46)?
I ran into the same problem with the "Timeout!! (FirmVer)".
Tried on both Windows 10 Enterprise 64bit and Windows 7 Pro 64bit.
Turning the radio on in "CP Mode" by pressing Squelch + Power on,
then starting the YCE46 CPS and trying to read from the radio,
and the text "PC Connected" appears in the display of the radio,
then shortly after, the message "Timeout!! (FirmVer)" pops up on the screen.
No other error message.
Alex
Right here ,
A software version
main: 01.01.00
Date Aug 31, 2021
Sb: 01.01.00
: Aug 31, 2021
‎Ici‎
‎Date 31 août 2021‎
Sb : 01.01.00
Le problème rst lié à la langue du système d'exploitation.
Cela se produit parfois lorsque le format régional est différent de l'anglais américain.
La seule solution, pour le moment, est de changer le "Pays ou région" et le "Format régional" pour English US.
