galaxy 33 dx hml
Silver Knight
Apr 5, 2005
27
Here is my question I took the radio oudt of my van and put in my basement later I hooked to a power supply when I turned it on the fuse blew. Replced fuse and it blew too. Where would I look for the problem? I'm nodt good width eletronics.
should be D93
unsolder 1 side of the diode,lift the leg up
set the meter for diode check or the lowest ohm reading
pos on one side of the diode neg on the other
change wires around if it 0's out on the meter then its no good
you should get a high reading on one side of the diode and no reading on the other side if it is good...but believe me its bad and if not .well your looking at a power regulator then..<..which ain't easy to pop
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
