if you build it........they will come
im waiting for a 9 pill Kraco (1x2879 driving 8x2879)![]()
HAHAHA A 9 pill kraco. That would be hillarious. Wouldnt be much of a radio anymore would be more like a slip seat box.
"it has 4 -2879s amp draw is 22amps........"
14VDC X 22A = 308W DC INPUT.
in your dreams. how do you get 400W out if the DC input is barely over 300W?
second of all, the PEAK current draw for 4X2SC2879's is right at 80A., not 22.
hell, the amp is FUSED higher than that.
14VDC X 80A = 1120 DC INPUT........
@ 50% efficiency that's 560W OUT.
as far as the 1446 is concerned the difference in power output between it and a 2879 @ 27Mhz. is on the order of 10W.. with 4 devices that's 360W for 4XSD1446's and 400W for 4X2SC2879's........@ 50% over spec that's still 135W for the SD1446 and 150W for the 2879........
it's a lot of talk about nothing.
hey 4600 turbo you got any pics of this bad boy.(the 98EXP)
Does the receive "S" meter respond to a strong signal or even a weak signal just trying to establish certain criteria before going to a do this or that idea?That's right and I didn't say I've checked it with and without the amp section in line it is in the radio not the relay in the amp.
