Beg, borrow an analyzer is your best bet.
Or get a nice pair of comfortable tennis shoes.
what about steal, I could plan a daring midday robbery of the local bank and use the funds to purchase one.
If you do that you will not be building any fan dipoles, but you may meet Bubba while you are locked up.![]()
so i am guessing that I am way off here... but would a 160m (1.8-2.0MHz) dipole work on 80m? I mean if you take the center of the band and multiply it by 2 you get a frequency slightly above the center of the band, but still within the band on 80m.
Am I on on target so far? Or am I missing something here?
Will it work? Yes.
How good will it work is another question.
Think odd harmonics.
So does this look right? I figure I should make the legs oversized and trim down as needed. As for 10 meters I guess I could use this old A99 I have laying around
136’(160m) on each leg
________________________________I_________________________________
70' (80m)
35'(40m)
18' (20m)
Then I would use your vertical A99 for 10m, 12m, and 15m and put 2 -1/4 wavelength radials for each of those bands mounted at the base of that antenna at a 45 degree downward slope. That will give you a pretty fair spread.
But that is what I would do . . .
neat idea, BUT wouldn;t the 15m band be covered by the 40m on the 3rd harmonic?
<More audio><More audio><More audio><More audio>...With a good manual tuner, I'd just use a center-fed doublet as long and as high as I could reasonably get it, feed it with 450 or 600 ohm parallel line through a balun and get on the air.
