Grundig broke ?
Weebles, wooble but they don't fall down!
Hand capacitance is happening here.... caused by a bad or missing ground or shield. The SSB and SYNC are essentially an inserted carrier that you tune with the VFO and fine tune with the BFO. The schematics for this radio are not to be had so it is a tough one to work on. The simple cure may be an alignment! <More audio> There is a Yahoo group for the Grundig G3 and I am a moderator there, more answers can be found....
73 mechanic
73 mechanic
Okay i guess i should take it apart and see if i can find something broke? This sucks because its brand new.:bdh:
If it is brand new; then it should be under a warranty. So, don't open it up; but send it back. That is what I would do.
Dnt have gift reciept? But I do have all the boxing and stuff. Not going to open it because I am sure its similar inside to the g6.
The G6 and the G3 are different animals based on the same design! The G3 uses a dedicated "radio on a chip" built right here is the USA by Silicon Industries.... Only real problem with it is that it is deaf above 21 megs. Minor problems are intermods and images along with some after stage IF mixing problems. :cry:
The G6 is an older and dare I say analog design? I have one but it is really over sensitive on receive and has troubles with images on the bands when they are crowded.... I have to "PAD" the signals to rid the excess! Other than that it is a neat and tiny rig! :)
73 mechanic
73 mechanic
Good to know. Well got the receipt for the g3. So I guess ill exchange it for another. Insted of sending it out paying shipping and all that riffraph.
I enjoy the g6 a lot but ssb is easier to tune on the g3, and the g3 pics up 27mhz much better than the g6 wit a dipole but there both pretty deph after 24mhz.
Sent from my Xoom using Tapatalk 2
Ok made the exchange, wow what a difference! Sw is once again much more beautiful!
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
