Help needed Air command superscope CB-640
3pinplug
Jul 23, 2016
30
4
18
56
Hi all
Just picked up one of these but it has a problem and was hoping some of you guys may be familiar with this radio, i am in the UK so we don’t see many of these.
The binary code is stuck on the ch9 code no matter what channel you select. The Vco appears unlocked as when i try to set the vco coltage via L216 i either have 5v or zero, also have no tx due to the vco issue.
Anyone familiar with these and can help?
Thanks
Mark
+1 with @unit_399 on this - if the front panel has a CH9 switch - and it was pressed in while it was in storage - they oftentimes develop a memory where the plunger and it's carbon button - won't change state to open up and restore operation.
So look for and see if reheating the channel 9 switch solder contacts can make it recover.
The Channel 9 switch on many CB's was a set of diodes, but some PLL Chips had a direct Channel 9 pin that if shorted to ground, can be unsoldered but be aware of static or poorly done mods or if zapped with static, Channel 9 that's all you get - the PLL chip is toast and the ability to change channels went with it. (CMOS PLL types are notorious for this)
The PLL's with a set of diodes also used a separate pole of the switch that applied power to the front channel selector so it can change channels by logic state (Hi-Lo) that if left floating - the PLL ignores any input.
I hope this is a schematic to your problem child...
The Radio above uses a "Scan" function similar to a squelch - that keeps Channel 9 in a monitor mode so you can listen in and help others.
IT uses a jumper - I'll let you discover the rest.
Reactions: DoctorAudio
All of the Superscope mobiles (CB-140, CB-340, CB-640) use the same PLL board. The board is double sided and has several feed-through eyelets that connect the top traces to the bottom traces. They are notorious for losing connection. 9 out of 10 times that one of these radios is having PLL/channel problems, one of the feed-through points is the culprit. Just re-soldering them won't always fix the problem as the hole design invites air bubbles when you try to flow fresh solder causing a continued bad connection. What I do (which I also do to double sided Royce boards that have feed-through problems) is to clean all of the feed-through holes out with solder braid then run a short length of solid wire through each eyelet hole before filling with fresh solder. This ensures a good connection.
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
