I have this workman watt/swr/modulation meter. A while back i noticed when wiggling the antenna out connector on the back , signal would cut in and out. Looking inside there is a brass threaded rod or screw coming out of the center going into a copper tube and kinda screwed into or pushing on a insulated wire. I soldered the brass screw to the tube once and that fixed it, but after a lot of use it broke loose again and also the input connector is loose too. What is the best way to fix it, just solder it again? Is it junk get a new one? For the life of me i cant figure out how the rf flows thru here, is the tube the shielding and the wire the conductor? The wire comes out and is soldered to the bracket that holders the connector.
