how best ... Baofeng UV-3 or UV-5 ???
1enry1
New Member
Jun 25, 2014
12
hlep...what i buy ???
some ham say that is very best UV-3 , (but have in 2012 !!! some problem , like low modulation, spurios in 144 mhz ... etc .... now in the 2014 baofeng
FIX it or not today this bug ????)
nad some HAM say that the UV-5 is not very good and the rx not very sensible. its true or ?
what i but uv-3 or uv-5 ???? help me.... tnx and 73
I think the newer releases are fine. The UV-82L is a very nice unit as well.
Just pick one with a recent manufacture date and you should be fine.
they're both the same as what's better. The only thing distinguishing them from each other is the features. so I would put more research into what features you like
Uv-5r no question. Works good with dual antennas
Say it ain't so! :laugh:
I've had very good luck with both the UV-5R and UV-82. Nice little HT's for the money. UV-82 fits my hand better, but then again, I like the compactness of the UV-5R. UV-82 gets better reports on my audio (not as "tinny", and more full bodied). Really can't tell any difference in the receive.
73,
Brett
ok i buy UV-5....
some questions:
1) now what is the latest FW , 2,91 or 3,20 or ??
2) if is not expanded (mod) in how mode i expande ? ONLY via cable to pc, or there si a keyborad combination or ?
3) there is a secret menu ?
4) is possible to have back screen lcd and blut dot numbers ?
5) in how mode i put a "alfanumerics carachter" in the memory ? is possible
via key on the rtx or ONLY via calbe to PC ?
hi, best 73
ok i buy UV-5....
some questions:
hi, best 73
1. does not matter, they all work the same
2. Expand what? They xmit from 135-174/400-470mhz
3. No
4. No
5. Yes you can do it via the KP but a PC is much easier.
tnx.... great !!!
now,
you say is possible to put alfanumerics caracters in the memory, by the keyboard...but in how mode ? what is the procedure ?
and i read in a forum that a buyer say that the his UV-5R buy work only at
144-148 and 434 - 438 ...NOT MOD !
??? you say all is expand in tx ? shure ?
  • @ wavrider:
    sea que sea que,
