HR2510 replacement lamp?
EDUK8TR
Well I tried a search on this in this subject area with no results. I thought the topic was here previously. I need to replace the lamp that back lites the display on my HR2510.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/indifferent.gif ALT=":|"> Does Rat Shack carry these?<img src=http://www.wwdx.org/smilies/posticon60.gif ALT=":60"> If so, what specially am I looking for when I go there? <img src=http://www.wwdx.org/smilies/posticon34.gif ALT=":34">
<img src=http://www.wwdx.org/smilies/posticon58.gif ALT=":p58">
Wayne C.
CDX-787,AK-2787
mobile/base
Magna Force 900/Magna Force 1000
HR2510/Kenwood TS-430S
MR. COILY 32 inch mast Single Coil/Wolf Radio.64 wave ground plane
D104M6B/D104w/Heil HC-5 element
Every man is a damn fool for at least 5 minutes every day; wisdom consists in not exceeding the limit.
</p>
Wayne C.
CDX-787,AK-2787
mobile/base
</p>
You can do a couple of things. I first got a small screw-in lamp and socket to replace the bulb in a Lincoln, then I tried an LED in an HR2600 I had a wide angle LED that I ground the top down some to diffuse the light more evenly. Both worked pretty well, of course the LED will last longer though.
</p>
</p>
And of course...
the standard Lamp in the HR series radio is a 12v to 14v lamp.
sometimes called a "Grain of Wheat lamp'.
It fits into the Orange Lamp boot in in the light frame.
I have seen exact replacement boots in Green in Yamaha Stereo equipment.
Roger
</p>
And of course...
Roger
</p>
It would have been nice if Roger posted a, if not more, of Yamaha equipment had this elusive green boot.
  • @ wavrider:
    sea que sea que,
