Icom 706MKIIG
555
424
20
flipping thru all the bands and modes listening and once i get to the 25.0000 range up to the 28.000 range it has alot of static in the AM mode
every where else its alot quiter
Is there a Filter that needs to be installed ?
or what can be done?
this is a nice little rig and i enjoy listening to everything
Is it there 24/7 or mainly just during the day? Is it worse some days than others? Are you sure it's not just the normal noise from a few million CBer/freebanders running in that part of the spectrum? I know anywhere in the 26.000-28.000 MHz block the noise level is MUCH higher than anywhere else because of that. Also if you are using an antenna tuned to that range like a typical CB antenna then you will have greater sensitivity there.
Reactions: 2 people
That could be the possibilty
Collossal 5kw
Of course it's going to be noisier in that freq range on AM. It's a 10-11m vertical. It's not going to be resonant anywhere else so it receives better in that freq range. AND it's a vertical antenna so expect more noise than a dipole. Noise is mostly vertically polarized.
Reactions: 2 people
  • @ wavrider:
    sea que sea que,
