I'd like to carry a 1/4 wave whip in the Jeep but...
rixdafix
561 Missouri Mobile (WDX561)
Dec 19, 2022
111
291
East Central Missouri
they're so dang long. Is it feasible to cut a whip in half and connect with an appropriate collar for static use? Or use two shorter whips in the same fashion to make a tank whip like those sold in the UK?
For static mobile use, I think you could cut the antenna in half, then connect with a couple of set screw collars. Overlap by a few inches and tighten them down.
Hahiyo Set Screw Shaft Collars One Piece Design Bore Zinc Plated Carbon Steel Solid Collar 1/4 inches Inside Dia Bright Finish Corrosion Resistant 4 Piece Heavy Duty for Dolly Wheel Handtruck Tire https://www.amazon.com/dp/B08TMCY6Y2/?tag=worradfor-20
Reactions: rixdafix
  • @ nfsus:
    RFactive has left the room.
  • @ Tim Chambers:
