'K.M.D.',
If you ever find -one- antenna that covers all the bands, get two and send me one! I'm afraid there just isn't any such thing that isn't very, very limited. Having said that, there is an alternative if you are going to be limited to just -one-, and I think you may already have the idea. A good, meaning large in size, antenna tuner capable of doing a random-wire antenna is probably the 'best' bet. That random-length wire should be as long as possible, or something like a 1/4 wave on the lowest band of interest. For 160 meters that's in the neighborhood of at least 120-140 feet, give or take some. Doesn't really have to be absolutely straight, it can bend, just not back onto it's self, sort of. It should also be as high as possible. The 'catch' with end fed wires like that is that they need a very good ground system, forget ground rods, they won't even come close (bury as much wire in the ground as you put into the air, 'times' three or four is even better).
Or, a doublet antenna as long as possible, fed in the center with ladder-line. A 1/2 wave for the lowest band of interest is nice. The other nice thing about doublets, or dipoles, is that they do not require a huge ground, none at all really.
Why a physically large tuner? 'Cuz the required capacitance/inductance at some frequencies will be quite large thereby requiring quite large capacitors and coils. You just can't cram all that into a small box. Manual tuners are better at doing that sort of tuning than the automatic ones, not to mention being cheaper! A few index cards to keep settings notes comes in handy. Are they difficult to use? Not really, and if you keep notes, the first time almost always takes the longest to get it tuned right. After a bit you won't need the index cards, you'll remember where things should be, sort of. 'Sides, twiddling knobs is fun...
