installing 8' fiberglass antenna on pop-up camper?
1slim
Guest
i'm gonna install an 8'(96") fiberglass whip
on top of the ol' pop-up.question is how long of
coax would you recommend starting out with,18'?
it will be centered on the rooftop and the rooftop is all metal and grounded well. my past
experiments have usually worked out pretty good
w/18' of coax.to adjust the swr would you suggest
trimming the whip or adjusting coax length?
i appreciate all your input to this matter!
now i just hope the wife doesn't get too upset
w/me in my little project! thanks,slim,cdx-285
</p>
</p>
Someone correct me if I'm wrong, but I seem to remember that for most antennas you only need as much coax as it takes to get to the antenna...and for tuning you always adjust the antenna, not the coax.
</p>
</p>
Use whatever length coax you need. Adjust your antenna not the coax for best swr. Make all antenna adjustments with the pop-up erected and the sides pulled out. Do this away from buildings and power lines. You might consider installing the radio and antenna then making your adjustments at the camp site. Enjoy.
Main</p>
Main</p>
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
