I've got the bug to buy another radio...
KJ4VRQ
Sep 9, 2013
86
23
18
I have a Yaesu 897 that I run as a base station and it works really well. My only dislikes is that the 897 only has one HF antenna port and one VHF antenna port. So, because of that, I have to use an antenna switch for HF to switch between my Antron and the G5RV. It's not that big of a deal but at one point in time, I had a Kenwood ts2000 that had two HF ports and it made things a little easier.
If I was to buy another HF radio, I would most likely have to sell my Yaseu in order to pay for it. I have been looking on ebay and I keep looking at Kenwood ts-2000's again. I sold the last one because I bought it with a credit card and didn't want to keep owing a balance...
Anyway, any suggestions? I know there are a lot of HF base radios out there. I'm looking for a bigger radio, bigger display, 160 through 6 and VHF capabilities, multiple antenna ports, maybe an antenna tuner built in but it doesn't have to be...
Any ideas?
Want HF/VHF/UHF you don't leave yourself many options +3 or more ant ports
IC-7600 or better! The TS-2000(Never like the HF RX in that radio) and that's about it...
Personally never like the DC to Light in one box idea....Loose one/Loose it ALL
All the Best
Gary
Reactions: 3 people
I have to use an antenna switch for HF to switch between my Antron and the G5RV. Anyway, any suggestions?
If you didn't want a new radio, what are your thoughts for a 2nd radio dedicated to the other antennas? I like to monitor a local 6m repeater and work 20m on the other HF rig.
I have been looking at the TS-2000 again but there are only two on eBay that I have found.
Sent from my iPhone using Tapatalk
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
