Just installed a 72' end fed and have a few questions.
If I put my ohm meter on the antenna 1 or 2 and the radio input I get no continuity at all. On either Antenna One or antenna two. I do get continuity on bypass one or bypass to and dummy load. For some reason there is no connection between input and .output.
Reason is really simple. It is differential T tuner. :D
I would worry if it show continuity.
Mike
Reactions: Road Squawker
Can you tune your antenna with that box?
Can you post good quality photo of it's insiders?
Area where switch is connected with air capacitor.
Mike
Mike at the risk of sounding stupid which I already feel I am I have to ask you a question. Why this being a differential tuner does it not show continuity between transmitter from the back of the radio and antenna number one or antenna number two while in tuning mode? But while in direct antenna one or two it shows continuity. Thanks
By the way the tuner works but the internal meter sucks.
So to add to my confusion this tuners internal meter which is pretty useless unless you use high power does not work at all unless it has power going to it. I had to reread the manual. so everything is working. Now tomorrow to take the cover off and fix the problems. loose screws, broken wires Etc.
I do appreciate all the help.
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
