........It can be replaced, but with alot of work. First take a desoldering tool (solder sucker) and after removing load, remove the solder from the top of the mount. Now the fun part...take a small flat screwdriver, and gradually pry up the cap on the bottom (looks like an old metal bottelcap) where the coax goes in. Be sure and pry up on the cap and not the plastic lip that the cap snaps over. It all comes out together (coax. "bottlecap" and capacator) When you put the new coax on, make sure everything goes back the same way.....especially the capacator. I've done a few with good results......I just wish they were as easy as the Wilson.zumlin said:I Wish the coax was replaceable, seems with the K40 you have to buy the whole assembly, or splice the cable and that cant be good. Woud be nice to put a nice piece of cable on it.
PLUTO said:........It can be replaced, but with alot of work. First take a desoldering tool (solder sucker) and after removing load, remove the solder from the top of the mount. Now the fun part...take a small flat screwdriver, and gradually pry up the cap on the bottom (looks like an old metal bottelcap) where the coax goes in. Be sure and pry up on the cap and not the plastic lip that the cap snaps over. It all comes out together (coax. "bottlecap" and capacator) When you put the new coax on, make sure everything goes back the same way.....especially the capacator. I've done a few with good results......I just wish they were as easy as the Wilson.zumlin said:I Wish the coax was replaceable, seems with the K40 you have to buy the whole assembly, or splice the cable and that cant be good. Woud be nice to put a nice piece of cable on it.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
