Welcome Ray119!Can you tell me how you hooked up the primary side of this transformer. I'm trying to istall the same transformer into my SB-1000 and cannot fighure out the primary side for 240 volt.
The one remaining item on the modification wish list is to beef up protection for the meters. A current surge from a bad tube can damage either or both meters. A back-to-back pair of diodes will do the job as a rule, but I would rather have a 'sacrificial' 1/4-Watt resistor in line with each meter to serve as a fuse. This is still a work in progress. Ought to write up the rules for protecting analog meters this way.
Later.
Looking for a transformer for AL-80A amp.If you run into anymore of these. I have 2-3 of these brand new transformers.
Looking for a transformer for AL-80A amp Bill K3HZP.If you run into anymore of these. I have 2-3 of these brand new transformers.
