Little tarheel ii install
My plate will be a little smaller.
I don't recall the brand of aftermarket antenna controller that I used but it was easy to operate.I never used the switch that came with the TARHEEL II just the other controller. It was quick & required just one push of the tuner button on my ICOM 7000 & it was done.
SIX-SHOOTER
That 32" antenna whip was designed for complete coverage for 10-80m so a longer whip will lose tuning of some upper bands. My guess with a 56" whip your highest band will be 17m. Your efficiency increases some but the trade off is losing the upper bands.
When parked, I'll put on a telescoping 17ft whip for much improved efficiency on 40 and 80m but I even lose 20m unless I collapse the whip down a section.
The West Mountain Target tune works well but I didn't like all those wires going to the control head. The Tune matic lite is a good compromise for semi auto-tuning and less extra cables.
You will get everything except 6 meters with the 56" whip.Been there & done that & it makes a big difference on 40 & 80 meters.
SIX-SHOOTER
I got the 56" loading up good on 80/40 now. I don't like losing 6 meters. I've been making a few contacts mobile lately. I also use our local repeater. Oh well, I'm satisfied with 80/40, as that's the majority of where I'm going to operate.
6 meters is cool, but it's even cooler mobile. Maybe I can rig up a quick whip change.
Reactions: W4KVW and Slowmover
  • @ Tim Chambers:
