good point Tim. This truck stays on highway, but it goes to hospitals, so landscape could be a issue, I didn't think of that. I put it out there as Hammer pointed to the article about getting it out away from the metal surroundings, though that didn't seem to have much affect as when it was mounted up high away from ground. I was going to try wrapping with some tape and see what the results turn out on the analyzer and see what differences show up.
Getting a good earth ground seems to be the key with screwdrivers, and getting them low and good connection to the frame seems to be the key. That's what the Tarheel support stressed as to where I had before was problematic. This box has all kinds of good ground plane, it's all metal, but it wasn't getting an earth ground. This has been a learning experience. Mounted on that front bumper seemed ideal as it's connected to frame directly and there's nice wide flat metal going to frame, supports, that make a good rf/dc ground as well. An interesting side note, is the high bands are affected somewhat if the 80/40 is not set correctly. I had it set to 50ohm x=0 reactance and 1.1 on 80 and close to that on 40m and the higher bands were affected in the sense that 20m was a little above 2.1:1 and higher loss and seventeen was not as bad but not as close as I wanted. When I followed the article and Tarheels direction and got the 80/40 closer to 40 ohm x=0 1.1 swr the higher bands fell right into place. I don't have it perfect 80 is more like 47 ohm. If I squeeze the coil tighter 80 gets closer to 40 ohm.
I just don't remember if that means I need lengthen or shorten the coil? I'll post a pic on here how it was mounted before I moved it.
I'm surprised though, that just a one outer wrap on the coil would mess it up as the wire is coated already. I was thinking this would be great to keep the coil in shape. I can see the guys at the truck wash blasting that coil out of shape as well.
I'm going to do some fine tuning this weekend and some more strapping as I have some light rf still, especially if I run the mic over 20%. I hate to see rf, I just want an over mod report.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Doc, I was worried a little about one of us taking some flesh off as well. It doesn't seem to be a problem as you see that antenna very well, yikes it's big, and naturally walk away from it.
This is the way I had it mounted prior. The angle of the pic doesn't show, but the decoupler was around 3" above the roof, which was fine by Tarheel's specs, but was just to far from the ground. The cap hat wasn't going to work though, too close to metal roof. I tried raising it to no avail. The height as it was with a 4' whip was still at lower position near 15' and at 80m would have been about 16' 6".
