Hi I have a 10m mobile whip in the loft with 4 3 ft steel rods as ground radials, they are on the loft boards holding the antenna up, but I want to add 4 additional 9 foot wires, stranded copper 5 amps rated and insulated, my question is how many watts would be safe before the insulation started to melt, I would only use 10 watts because its in the loft but if I forgot and my FT950 was set to 50 watts would that wire heat up ? its going to be attached to a 4 bolt mirror mount and i was thinking it would act as a heatsink for the wire ?
