looking for someone that can build a 3 or 4 3- 500z box pm me all info i would appreciate the help!!!!!!!someone that can be fully trusted and wont burn nobody thank for thye help
I encourage you to do that Chris, so the guys here can look at them and know what to look for in a custom built Amp, before plunking down there hard earned monies on a "three mile island" Box.I should put up some pics of poorly-engineered "big" tube boxes we've seen.
nomadradio said:Hmm. That guy probably wouldn't want to be advertising on the web. Yeah, I know some of them do, but they seem to fall into two categories.
First is the guy who'll apply commercial-grade engineering, with all the small filtering components, internal shielding and overload protection for both the tubes and the power supply. The sockets will have air flow BOTH on the underside of the sockets and on the glass topside. You wouldn't believe how many "expanded" SB-220 chassis I've seen with NO air on the undersides of the sockets. The factory-stock fan on that model blows BOTH on the topside and underside of the tubes. Don't think I've seen ONE modified SB-220 that did.
This guy will probably quote you between $5000 and $6000, and always gets underbid by the second category.
These outfits build "gutless wonder" boxes, in which a component gets left out UNLESS it contributes to making the wattmeter needle go farther. Parts that keep the tubes stable, parts that limit tube damage during a surge, parts that keep the signal reasonably clean, all get left out. That's how they underbid the first guy, by cutting corners they think the buyer won't know about. Not until the first set of tubes goes flat. Usually way too soon.
I gotta ask, why you want that many 3-500Z tubes. Sure, when there were made and sold by multiple sources they were very cost-effective compared to other, newer tube types. My problem is with using more than two of ANY tube. If you need four tubes, what you REALLY need is larger tubes, or one that will do the job alone.
I'll skip putting you to sleep with the added risks of using three or more tubes together. Just consider that with one tube, you have one chance of tube failure. A box with four tubes offers you FOUR places(chances) for that same failure to happen. Makes it four times as likely, all things being equal.
Consider also, that if one tube fails a year or more down the line, you can no longer just pop a NEW tube in with three older, tired tubes. Even if they still deliver 90 percent of what they did when new, the new tube will pull more than just one-fourth of the load. The parts of the load that the older tubes WON'T pull, will ALL get loaded onto the new (meaner) tube. As a result, it tends to pull more power than it can take, and fails far too soon. UNLESS you watch that one, and throttle down below the danger point. Throttling down is almost never what a guy with four 3-500Z tubes will do voluntarily.
If you have to replace all four tubes just because one (only) failed, the upkeep price of this thing gets a lot higher. A box with one or two tubes will never need more than that to put it back on the air.
Too bad Henry Radio no longer makes their "5k Classic" model. It used two 3CX1200 tubes. Each of them is a little larger than one pair of 3-500Z. Requires LESS drive, to boot. And that tube is one of the stoutest that Eimac ever built. Worth considering if you plan to run AM. AM is just hard on an amplifier if it was designed with SSB in mind, like all commercial ham linears tend to be.
I should put up some pics of poorly-engineered "big" tube boxes we've seen. Some of them are pretty hilarious, so long as none of your money got tied up in one of them.
Try http://www.wizardbuilt.com/shop/?shop=1&cat=5&cart=19395excavator701 said:looking for someone that can build a 3 or 4 3- 500z box pm me all info i would appreciate the help!!!!!!!someone that can be fully trusted and wont burn nobody thank for thye help
are you comparing the drake to a heathkit?JustinDePolis said:A SB220 driven by an SB-200, OUCH!!
