Maybe it's using JB Weld or something else strong?
Well Moleculo, I wouldn't depend on JB Weld either with all the twisting around and bending going on with the long top loaded radiator in the wind.
I looked again and the mast can't drop down onto the bolt because the tap point is located right at the top of the insulator and that would stop the radiator from dropping down.
My main concern still would be what is going on inside the insulator. That tubular insulation material can't possibly be very strong. If it was surrounded on the outside by a heavy metal outer aluminum tube like the image below, and it was directly attached to top of the hub or the hub could be fitted over the outside of the base mast bracket:
![p50-05.jpg](/proxy.php?image=http%3A%2F%2Fwww.wolfradio.com%2Fpics%2Fp50-05.jpg&hash=cf30756ec3ae0d6aed578a2a407e5c48)
There are several options I could see that could be designed to add better support of the radiator in the insulator if there is not support inside.
