I can barely work with 1/8 watt resistors my friend...I'm using this now:I think it would work, but if you don't mind sticking leads on a surface mount part, there is one with a closer voltage (9.65) rated at 1w
KDZVTFTR9.1B | Digi-Key Electronics
Order today, ships today. KDZVTFTR9.1B – Zener Diode 9.65 V 1 W ±6.04% Surface Mount PMDU from Rohm Semiconductor. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
maybe a little scrap of board cut from a spot with parallel traces that can accommodate both the part and leads.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
