Need help with antenna for a dump truck
Ku8b25
New Member
Mar 13, 2014
4
I have a 2002 t800 dump. The cab is fiberglass with aluminum doors. What would be the best set up I could go with. I have a general hp40 peaked tuned with great coax now..thank you for your help.
I've been working in Mexico recently and have noticed a majority of this style truck have a whip mounted on the nose of it. I haven't decided yet if it's practical to avoid bending it on low trees/bridges, maybe doubles as a gauge for low height obstacles, or if it's just due to the cab and not wanting to run a dual setup. But almost everyone of the big trucks have it mounted directly above the brand emblem.
Interesting.. I just think if coil was higher it would work better in my setup. My box sits higher then the cab by a foot. I also seem to get a lot of noise static. From the Wilson moving or sitting still.
Got a radiator out there on that nose of the truck? Is it metal? Is it connected electrically to the frame of the truck? Can you mount that antenna out there on that radiator? That would seem to satisfy the electrical requirements, I just don't care what the 'looks' of it would be. Would it be the 'best' place to put the thing? All things considered, probably. Is it the 'classical' antenna mounting place? Nope, but so what, it's the -best- you can do under your circumstances, which determines the 'best' place you can put an antenna.
Next question??
Wilson trucker 2000
I have several dump trucks on the road and switched the antennas to wilson 2000 with the 5" shaft. I can say that they are tough I have not had to replace any of them and it has been over a year. I had the fiberglass ones before. I would also look at the K-40
Reactions: Groundhog KSS-2012
I have helped a few of my friends with dump trucks. The best I have found is a dual antenna mirror setup with counterpoises on each antenna.
imo a truck that the antenna is hitting trees ect go with a steel whip. the ,,springer,,(try google images) is pretty much quarry truck and 4x4 or farm vehicles antenna of choice in england.
if its open highway they still work well as does a decent ,,halfbreed,, type steel whip but you can now go with pretty much anything
so a typical flexi stik type over 3 foot should do ok
as for the valor halfbreed copies
these do vary a lot so go with a known brand (solorcom for example and get the long one.
you may well bend it sometime but just bend it back! also single antennas are just fine! less hassle less expence less repairs and easier to install infact i see a lot of trucks up close and sometimes 1 isnt even connected or its for just the amfm radio. twins also really need to be 9 feet apart so all the twins you see on pick up trucks ect behind the cab is not a good idea. a single up on the back of the cab roof
of pretty much any variety over 3 foot set up right will do better
as for fibreglass cabs you can fit antennas on a 90 degree right angle mount as high as possible and also directly through the roof with a dv or stud mount.
on some i have simply ran a cable from the earth side of the ant mount down to the frame.
on others i have used aluminum tape to cover the underside of the mount area as large as easily possible as if it were metal.
a dv27 on a biscuit tin was the typical new beginners home base set up back in the day
and it worked ok local and dragged in skip. so you dont absolutely need a big metal area but it does help.
i have also mounted one on the mirror and mounted a short antenna straight down on the earth side to make a minature dipole on a fibreglass door.
(you may find a base boomerang antenna works for this)
but you may find that if you look up around the back of the cab you can mount it on some metal there like an air cleaner or stack mount frame a lot of trucks have this
basicly just make sure your getting a good earth of some kind and the ant is up an in the open
hope this gives you some options
The gravel trucks we have here, some has those antennas are mounted on the mirrors and some runs a ss whip mounted on the corner of the front bumper, and runs a ground strap off the mount to the frame and runs the coax along the top of the frame into the radio......
To keep the whip from flopping all over the place, get a black rubber bungie-cord and take the hooks off the ends, and slide one end over the whip and close the other end up in the hood or tie/strap it off on the frame somewhere...
Long as the whip don't touch any metal anywhere u should be good to talk..
