New TS-590SG and TS-590DG and TS-590VG
KG0MN
Mar 5, 2010
166
42
38
Looks like they are going to offer a couple of different flavors of the 590
Than Kenwood brand, operability and excellent high reception performance, enjoy a comfortable Communications Inc. JVC Kenwood,※ 1as new products of amateur radio, early November HF / 50MHz transceiver to "TS-590 G" series I will release more.
※ 1: In order to use this machine, amateur radio license is required.
   "TS-590SG": 2 flax license more, "TS-590DG": 3 flax license more, "TS-590VG": qualification of four amateur license or higher is required.
Name of productType nameSuggested retail price
(excluding tax)Release date
HF / 50MHz transceiver (100W)TS-590SG $1,586.68Early November
HF / 50MHz transceiver (50W)TS-590DG
HF / 50MHz transceiver (HF: 10W, 50MHz: 20W)TS-590VG
"TS-590SG / DG / VG"
Reactions: 2RT307
I think you are a bit mistaken there ... (In order to use this machine, amateur radio license is required) .... Actually all you need is an AC power supply and an antenna. Cheers.
Reactions: 222DBFL
Nothing on Kenwoods site or a google search turns up with these new series radios.
Where did you get this information at?
What is a Flax license?
April fools has already passed.
Anyone can buy these radios but can only operate on the amateur bands according to their license class.
So if you don't have an amateur licence - and you give it 110v and a resonant antenna - it won't work? hehehehe
"TS-590SG": 2 flax license more, "TS-590DG": 3 flax license more, "TS-590VG": qualification of four amateur license or higher is required."
Huh??? This is nonsense. The 590SG was the only other version released.
Correct....13.8V will work however ;)
