no modulation
bluecurt63
Jun 17, 2014
31
6
18
ive got a brand new general lee just took it out of the box. It has no modulation on low power,ive checked the pots for low power . It keys up fine got good carrier on low power but no modulation.It works fine on hi power,got good modulation on hi power.but no mod on low power.
Better yet, find the trimpot that sets carrier level on "Low" and turn the carrier up slowly while modulating the radio.
Odds are you'll find the carrier level at which it breaks free from the limiter and the audio comes back. Since the radio modulates okay with a higher carrier level, we know all the other stuff is working okay.
Unless the Low-side limiter pot is turned all the way to the wrong end. I'd start with the limiter trimpot set so the DC voltage measured on the face of the trimpot is as low as it will go.
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
