Hello all..i waas wondering do any of you happen
to have on of these radios.What i need is a scan
of the component as well as the foil side of the
pc board of one of these in stock mode. I bought
one from a guy on ebay in non-working state.
But it has alot of add on parts,also a few foil
patterns cut with resistors and diode connected.
I am pretty sure this is not stock.But this is the
first one of these type radios,i have worked on.
The pcb does not have a number on it.But it
looks to me like a ept360014b clone.Seeing how
all the active devices,variables adjustments are in
he same locations..Really only difference is the tx-mixer
ic-9,is on the foil side of the pcb.And it is a postage
stamp style i.c.Also it has a swr shutdown board.
And a small 1 1/2 inch square pc board in front of the
echo board.Which has two mic jacks on it.One is a 1/4
inch jack,and the other is a 1/8 jack.And like i say alot
of suspisious looking added on parts.Resistors,Diodes
S.M.D. TYPE diodes.and a small variable..I am thinking
probably half this stuff is not factory.But like i say,this
is the first one of these ive seen,so really dont know.
So if someone has one of these radios.And can scan the pcb
or take maybe a couple of pics with your cam and post
them.I would surely apprecate it..I have been told also
the Nt 3 hp and Nt4hp has same boards also...THANKS
