I'm trying to set up my Yaesu 8800 for odd split repeater use. I have the radio set up per the manual, but I can't get it to work correctly. The repeater system does use DCS codes (seperate transmit code 23 and receive code 65) and I'm wondering if the codes are stored properly in the transmit split memory. Meaning, I've stored the receive set up with DCS codes into memory and it works for receive (I can hear the repeater when others are using it). All is good! Then I go the the VFO and dial up the transmit frequency and a different DCS code and go through the process to store this in the same memory as the odd split transmit freq. I don't know of a way to look at the this transmit freq to see if it is sending the correct DCS code since it is stored over the same memory. In any event, I've done the process several times and it does not work with the repeater. It does transmit on the odd frequency, you can see that when you hit the transmit PTT, but of course you cannot see any info. With the dual VFO feature on the 8800 I can set the left side to transmit and the right side to receive and I can make it work in that way, however, it should be possible to set this up to work as the odd split in the same memory per the manual. It should be noted that this repeater is outside the ameture band and on a work related repeater around 150 MHz. So, just wondering if anyone has had a similar problem or any ideas?
Thanks as always!
Thanks as always!
