original armadillo
Cali Jay
Jun 25, 2015
2
43
I bought an original Armadillo 2 pill linear from the late 70's (I'm told,) (Also not a guy that's ever been known, as far as I know, to make up lies to screw people over) that swings 450 and holds 350 continuous. It's seemed to work pretty good considering I had a really shitty set up at that time. But it's been unhooked sitting in my closet for about 3 years now. I don't really know much about them. So I really have 2 questions; Is it worth pulling out and hooking back up now that I have a good set up? And, did I get screwed giving a buddy $150 for it?
Hook it up see if it works and make some contacts.
The output wattage will vary from depending on what watt meter is used and how much voltage is supplied.
Did you get screwed?? That is up to you to decide
Reactions: Singularity35
  • @ wavrider:
    sea que sea que,
