Paladin Communications 300
Switch Kit
Apr 6, 2005
3,597
138
63
Amp looks very similar to the old Messenger line of amps . Up front , amp is a little buggy but works OK , medium side is out and the max side produces a very large DK ......with 2 watts in Low side does about 25 to 120 and High side does about 50 to 200 pep ......the SRF 2072's are 65 watt devices so there pretty much doing what they should. 60.00 Shipped Priority mail same day or next thanks for looking.CameraZOOM-20160412210725482.jpg CameraZOOM-20160412210648839-1.jpg CameraZOOM-20160414183017367.jpg CameraZOOM-20160414183117517.jpg
I think your thinking along the lines of a Texas Star and there power settings ? ......the answer would be no then . Weather it's on Hi or Low , the hi setting will remain the same ........if somebody could live without the medium and max settings .....they got a decent class C 200 watt'er . I think the numbers are pretty good with just about 2 watts in as is......or maybe they know a good amp man who could bring it up to par ? the bottom line it works as is and it's very clean for it's age. The one thing Switch don't want is to sell someone something they don't need.
