I found 100uf 450v axial caps. Are those sufficient?
How do you find the white relay you guys were talking about, the potter and brumsfeld one
If either or both of the white-plastic "R50" relays has gone bad, we have a drop-in solution for that one.
I have 18 guage 600v 150c braided wire. would this be suitable for the old 22 guage replacement?
Still at a loss for the relays/ numbers.
Those are the values called out in the schematic. They will work fine.
Mine were replaced by the previous owner of the amp. They are radial capacitors and are 120uF @450v.He was "inventive" about getting them mounted physically.
The picture below is from Nomadradio's post in my 300A "rehab" thread. This would be the only solution I would consider if the relays are bad.
David
I did find new ones. One amp I dont know nomads replacement relay numberDoubtful you will find those relays new.
A suitable used??? They are too difficult to remove and replace just to "try out" somebody's junk parts.
My opinion is Nomadradio's replacement is a best bet.
David
There is an ebay ad for the r 50 relay nib 2 for 11.95
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
