PC board trace on Grant LT
airplane1
Apr 15, 2005
1,051
32
58
Lebanon county PA
I got a Grant LT that is in decent cosmetic condition but will not do anything but light up and the channel display is dim at best.
Looking over it I see a burnt spot on the inside cover of the solder side of the board. I looked where the burnt spot on the cover lines up with the board and see a tiny spot where the trace is burnt and broke. I think someone did soldering in that spot and messed it up.
Can a small spot be repaired or is it shot? It is right where a diode is D44 and a resistor R51. In fact it looks like the soldering done there shorted these together.
I want to get this working if possible.
Thanks for any input,
AP
I don't see why it can't be repaired. Broken traces can be bypasses with wire jumper, or if you have access to advanced tools such as the Pace cir-kit, you can certainly fix the trace properly. As for the shorted-bridged components, unbridge them.
Thanks, I was just thinking of that last evening, putting a wire across to bridge it. There is a small board wired into the radio that I have no idea what it is for. I want to take it out and restore radio to stock.
I will post a pic soon.
AP
Some mods are not as simple to undo as just clipping off the accessory cards. The initial modification may have involved replacing resistors with different values, bridging/shorting connections, etc. I think you'll want to find out what that mod was first and what else might've been modified.
