I like the FT897, but don't like options for powering it in the field.
The internal batteries are expensive and don't last very long and recharging them requires taking the unit apart and couldn't be done in the field very easily. And to top it off, it is limited to 20W output. Although I have been told that 20W is good enough, I don't like being limited.
I am looking for alternatives. I am not an electronics guru.
I have come up with a couple ideas that I will run past the group.
Could I/should I, try to wire 4 RCR123A together get my power? Maybe multiple packs to get more mah?
4 Pack RCR123A 3V 900mAh Rechargeable Li-Ion Battery with Smart Charger
I like the idea. I use 123 batteries in other devices so...., but I am not sure I have the skills to pull it off.
OR
Wagan Tech Self Charge Auto Jumper 2045
Wagan AC to DC 12V Cell Phone/PDA Traveler's Adapter - USB 2435
It would be nice if I had one of these on hand in case I need a power jump.
OR
