Probably a longshot but i need a set of finals
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
3,835
5,095
523
69
number RD70HVF1. if anybody has next size higher rating but same physical demensions be ok. no used 1's please n not expensive either
Subbing one that's 'larger' inevitably brings about the need for some redesign. Component values in both the input and output circuits typically need to be changed if the transistor type is changed. A transistor rated for more output may or may not deliver it in a circuit built to match a smaller power transistor.
Reactions: Rwb
i went back with oem rated
