I recently got a new Uniden Grant LT and love it. They just recently stopped manufacturing them, but you can still find a few around. I think it might be one of the best CB's I've owned. The Texas Ranger TR-296 is supposed to be similiar in design so that may be a good choice. Another decent radio you can look at is the Galaxy 959.
For antennas, the sticks you mentioned will work fine. I use a 4' or 5' Firestik or Wilson (depending on my mood). With those stake pockets mounts, the antennas always seem to be cocked to to the side, but you can work on it to get it vertical. You could also look at a Magnet Mount Wilson 1000 or Wilson 5000 and put it right in the center of your cab. That looks good, and you still don't have to drill holes. The Magnet Mount antennas also come with the cable already hooked up so it's pretty trouble free.
Lastly, get a small SWR meter and a 3' cable jumper. You can get them for around $25. You will need to use that to tune your antenna properly before using the radio. Once youv'e done that you can take it out line and just use the radio and antenna. If you run into trouble with that, let us know.
</p>
</p>
