Radio Shack 2052
cbshack
173
6
Central Florida
Does anyone own this scanner? Any tips on how to program? I can get it to scan 1 trunk bank but once I turn it off I have to go into a trunk mode to get it to scan again.
</p>
I have the pro 2051 that i have the same toruble with. I cant seem to get it to scan all the trunk codes. Let me know if you figured it out. Or i will let you know if i find out.
This model is on clearance right now for $99.97 by the way.
Limited stock as they are clearing them out. In store only. So you probably will have to go to your nearest store and even likely they will have to locate one and get it for you in a couple days.
I just bought one today. And there were none in the store but locally (I assume a distribution point?) there were three of them when they called. So now there are three. But I assume that is regional.
  • @ Tim Chambers:
  • @ AWP:
