I'm using a micro relay to switch some stuff. The design is a constant 12v+ and uses a transistor to switch the 12v-. I want to put a delay in it with a capacitor. But where would you put that? Between the coil neg and ground?
You can put it directly from the relay + terminal to ground. You can use a much smaller value capacitor however if you put it on the base of the switching capacitor to ground as it draws MUCH less current than the relay itself.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
