The supplies should have come with some sort of operator's manual to tell you whether you can do this or not. Some Astrons have provision for it, but I'm not aware of Pyramids being able to.
If both supplies are of the same make and model and have the same voltage output then you can generally run them in parallel without an issue.Ideally you should have an isolation diode between them but it is not 100% necessary. Do NOT even think about using unregulated supplies in parallel however. Been there, tried that, saw the havoc it created, gave up on it.
Ive also ran 2 Pyramid PS52K supplies together without a problem just MAKESURE THE VOLTAGE IS SET THE SAME ON BOTH SUPPLIES. I also have metal lugs (Astron style) on the main supplies negative and positive because of the plastic knobs melting.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
