When making the ground bus, would it be better to use soft roll 3/4 copper or a straight stick of 3/4 hard pipe? Does it really matter? Is one more conductive than the other?
For what you want it will make no differance at all. The pipe actually has more surface area BTW. Remember to include the circumferance of the inside as well as the outside of the pipe when determining total surface area.If all I had was 3/4 wide strap I would use the pipe but then again I tend to do things the overkill way.
