solarcon antena install
fasteddie
Jul 20, 2009
56
42
upstate ny
just hooked up my new to me base antena solarcon. i have upgraded from a little will. all is good the little will hade high swrs solarcon is running a 1.5:1 on the match and the base of the antenna is abought 10 feet above the roof line. question is how do i tune this antenna if it is tunable at all. i know the swr is ok but i would like to get it lower
click to go to page and then click again to make it larger ;)
you adjust the tuning rings .
i was just looking for tunning instructions i'm not familiar with the antena. i have the power loss chart from firestick already, no i'm not satisfied with1.5:1 thats why i wanted tuning instructions. but the 1.5 is better than the 5:1 match that the little will hade would only reach 1/2 mile down the road, i'm getting abought 15 to 20 miles with it now depending on conditions.;)
Don't fall into the trap of thinking that SWR has any significant relation to 'range', it doesn't. It's about like saying your miles per gallon depends on the color of the socks you happen to be wearing. The color of those socks might indicate a particular mind set, or attitude, that may be a sign of you being in a 'frugal' mood. But that certainly doesn't mean that every time you wear that color you will get great gas millage. Same with SWR.
What!? I always wear my red socks to get the best SWR and gas mileage. . . now what am I gonna do???
no but it does make a difference when your only working with 4 legal watts and your trying to cut through the noise that is out there that couple of watts or couple tenths of a watt could mean the difference. i know there is alot more to it than that though.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
