Strange problem with Cobra 2000
1200RI
May 4, 2005
55
2
18
Smithfield,RI
My Cobra 2000 has a hot ground?If I put a volt meter from the spring of the D-104(- side of the volt meter) to the case of the radio there is 13.92+ volts?Does not matter if its on ac or a dc power supply.Its not the mic because I tested it with a my Grant Xl.If you get it close to any coax connector or case area's it will arc?I have been changing out caps one by one to see if I have any shorted ones.Any ideas?
I would start with the caps in the power supply. Start at the a/c input and work your way through to the final dc. I would guess it would be one on the a/c line if it's arcing.
