Stryker 955 Amp.
socially unacceptable ? Not as far as im concerned. I personally think reflect is more important than SWR even though they are a product of each other. Im looking at reflect on a bird meter with the slug in reverse way more than im looking at swr. if my reflect is very low to zero, i would not even bother checking swr. but thats just me.
On the other hand, im probably the dumbest person on the site. so theres that.
Well yeah exactly right.
I only monitor reflected power mobile but I'm also capable of the KW's range. In an emergency of course!
But very high energy harmonic output is going to reveal itself to the base level operator as a antenna they can't "seem to tune"
If you're running half a kw mobile and you radiate a piss ant 10 watts of harmonics you're not going to bother anybody. Hell even at home in the shack
Now the SD1446 final is capable of rated output at 10/11m 2nd harmonic. So those need to be treated differently than a Shiba 2290/2879 as for design
Thanks So much.
I am glad to here that. I was starting to worry that I would have the passenger seat of my truck filled up with an amplifier. I will check out the 500.
I know this is an older post but I’m curious what you went with and how did it work?
Reactions: Keto
I have been talking to Stryker Customer Service. They advised me that there is a guy in PA who is good with these radios. I am going to take a ride next week abd have him take a look at it. All I ave is a ancient Radio Shack swr power meter.
Who is the guy in pa...I need to have my swing adjusted...only swing 20 watts
  • @ Tim Chambers:
  • @ wavrider:
    sea que sea que,
