SUPER-SIZE MOBILE MOUNT!
Roger That
Mar 4, 2014
26
5
13
Parts Unknown
I was looking at new and different antenna mounts for my mobile when I stumbled across this monstrosity:
New 4 Magnet Super Mag Antenna Heavy Duty Quad Mount for CB Ham Radio Antennas | eBay
Looks like you'd need two people to effectively R&R this beast! Probably could get away with only two magnets, but four?? Are you driving around with an A-99 base station antenna? LoL
It gives me a Polar Vortex wintertime cabin fever project idea similar to this, only with two 5" magnets underneath a 102" whip
I bought a small box of stuff one time with a cobra 2000 d104 desk mic realistic desk mic and a speaker.and a mobile antenna. $150 cdn :p.not bad if ya ask me. I was surprised at the antenna that was in this.
One magnet. Same size as those in the picture. And a 7 ft firestick trucker style antenna. Im like wth who would drive around with that. Still not sure to this day. I however used it as a base antenna on the roof of my apt. Surprisingly it did pretty good. Even broke skip on the superbowl ch 6 with no power straight stock.
To this day I wonder who would need one that big with a single antenna let alone 4 magnets.
It seems you would do a lot of paint damage to the roof yanking that thing off and putting it back on. If someone needs a magnet mount that large, drill a hole.
Wouldnt having more magnet surface area improve the RF ground coupling to the sheet metel? I figured it would, but I dont know. This might be worth researching.
I'm curious , yes why not ? It has more metal so it should increase the ground plane effect , even if by a small amount .
Sent from my NB09 using Tapatalk
why take it off at all? with the right antenna this thing will shear through tree branches and low overpasses.
it's been a while, but I do recall being impressed when i took mine down after a year and a half. there was significantly less discoloration than I'd come to expect from a wilson 500 running the same output.
It may not supply a better ground plane, but it does distribute the flow somewhat.
I will concede that you might get an ever so slight increase in so called ground-plane but not worth the effort. There many variables in this as well, how its constructed, thickness of the metal, position on the vehicle and so on.
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
