it is not a hard test (thankfully)
Although many think it is
i have a friend who failed 3 times
trying to study on his own
then upon hearing he failed a 3rd time
i took him aside....set a apointment for the exam
day of exam...studied with him so he could understand what was needed (45 minutes before exam)at a internet cafe couple of blocks from the exam (so that everything was fresh in his mind)
then he passed fairly easily (even though he still was nervous as heck)
Anyways
these 2 sites always have up to date question pools
www.qrz.com
www.eham.com
I used qrz (just perfered their format)
read the currant book (or even if not most currant book is ok)
for a week or 2...
then keep the book as secondary learning device
(because so many people have huge trouble learning something like this via book alone)
then use qrz and or eham
(you need only take the tech tests)
Oh and since i went though the trouble of helping my friend learn what he needed to know..
and since i made a appointment for him to take the test
i figured i may as well take the test as well
i passed it on my first time (like i said it is not really a hard test)
so in using qrz and or eham to take the currant question pool tests.....once you continually get to point of getting 85 to 90
then you are ready for the test to be taken for real
i think it is importent
that you take the "practice tests" of qrz or eham
an hour or 2 before taking the real test
in this way it will be fresh in your mind
as well as curb any nervousness since you will see you just got 85-90 on "practice tests"
also
even if you start doing real good on practice tests
be sure to take many of the exams because you want to be sure to go though all the questions that are currantly in the pool
both qrz and eham
will explain the right answers for you in a manor to make it stick
they also will let you see what types of questions you are having more difficulty with....so you can better study up on your weaker areas
good luck
any other questions
just ask
