This is a one of a kind Mobile Antenna
Yes, that Is Sha Sha.
It is at the very least a unique antenna system.
Though it might invite a discussion about such a strange looking antenna.
Much different than the in-line Multi antennas that most everyone else is running.
Almost everyone else is running this type of set-up.
Note, link no longer valid, removed by youtube
( note this is a good reason not to key in the rain)
i'd like a peek in the van!
hard to tell on the antenna's...rabbit ears on each side?<<More audio>>?
i can see a trombone type match on the right side...
not sure what is on the back of the van attached to the trailer hitch-looks like another antenna
If you double click the link, then go full screen, you get a much better view, and can even pause the Vid to get a better look.
Looks like he is feeding both sides, and from the size of the coax, a substantial amount of power is being feed to them :)
Comments about the construction/type of antenna are what I Am looking for.
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
