I began to check tube voltages when i touched v302 pin 2 the am receive came back to crystal and manual mode. then i traced the static down to C311 there was no static on the other side of it. C312 has static on the other side. and R308 had no static on the other side of it. it measured 99k ohm its a 100k ohm resistor. Im having a difficult time understand whats going on and what i should replace.
