TS520s alignment issues
Oct 24, 2008
25
So I downloaded a manual for my new TS520s and I am try to do an alignment. I am following the manual but when I tweak the appropriate coils the S meter does not move. From what I understand I should be tuning the coils for max S meter deflection. I am pretty sure I am doing it right because I have read that section of the manual several times.
What am I doing wrong? :headbang
Dumb question here, but I'm assuming that you're trying to adjust the s meter while using a signal generator?
There should be a list of equipment that's required to do any sort of "alignment" on the radio, and it should be just before the step-by-step instructions. Do you have all that equipment?
The only stuff I need according to the manual is a VOM, tuning wand, dummy load and RF signal generator(S-meter sensitivity adjust).
I do not have a dummy load so I didn't do the drive coil alignment etc. And I do not have a signal generator so I did not do the s-meter sens adjust. I did figure out what my problem was early on... It seems the RX coils are not in the logical order I thought they were. Once I looked at the picture closer I notice the error and quickly made the rx adjustments.
I need to make a dummy load so I can continue. And that S-meter is still not right so I guess I need to use an RF generator.
Too bad I can only use the thing on 10 meters right now... I dont EVER hear anything that high. 40m is always busy. I need a mic anyway so it's no big deal right now.
Thanks
  • @ wavrider:
    sea que sea que,
