Im not sure if this is the right area to post this question or not but I was wondering if there was any diffrence between a hr-2510 and a hr-2600.what is the diffrences and which one is the better radio?
ok thanks for the reply back, I have a chance to get a 2510 or 2600 and was told about the chipswitch deal.I was just wondering which one I should invest in and have the chipswitch and mods done to it.
C2 is right. If given a choice I would go with the 2600 and have it chip-switched to access 11m. I like the fact that I can dial in a different freq for each individual band (0-4) and use it like a memory. That gives me 5 freq.s that I use most often that I can access quickly by just pushing the band button to rotate thru. Makes it quick and easy while on the road. There are a number of different mods that can be done. Which ones you want would be up to you. Personally I had the RIT, variable power mods and the finals changed out in mine. I have a 2510 that is not chipswitched but has the same mods and keep it as a backup radio.
